configure sshd2 user-key add user
configure sshd2 user-key key_name add user user_name
Description
Associates a user to a key.
Syntax Description
key_name Specifies the name of the public key.
user_name Specifies the name of the user.
Default
N/A.
Usage Guidelines
This command associates (or binds) a user to a key. Pressing TAB at the end of the command lists existing account names.
The following example binds the key id_dsa_2048 to user admin:
configure sshd2 user-key id_dsa_2048 add user admin
This command was first available in ExtremeXOS 12.0.
Platform Availability
